prophiseer has asked me to share my secert for doing lower intake manfold gaskets on these engines, if you follow these instuctions you should be able to do these intakes in less than an hour, THIS IS ONLY FOR PROFESSIONALS, the back yard mech should not try this unless they know what they are doing.
1. Get vehicle in bay and drain water out of it, while draining remove all upper plemum blots and map sensor, air cleaner and duct work (leave throttle linkage on maifold) and undue 2 bolts from coil braket, 2 hoses under thottle body, and remove egr pipe (leave egr on intake). next flip upper intake over some where on drivers side of car it will move plenty to get out of your way.
2. Remove power sterring pump bolts and position pump to side of passenger fender.
3. Remove Water cross over tube from water pump and postion it over with upper intake.
4. Remove 2 bolts from fuel rain and remove bolt from head holding fuel lines, lift out fuel rail complete with lines attached and carfullly position it over with upper intake and water pipe, the ass. will go over there just fine, and if you have it in the right spot it will stay there, and be plenty out of your way. then lossen the bolt for the heater hose in the manifold and slid the pipe out of the manifold.
5. Remove the front valve cover and rockers and pushrods
6. Get a 8mm wrench and lossen the 2 top valve cover bolts on the back valve cover, they will loosen just enough for you to finsh undoing them by hand and be out of the manifold, and the alt and coil packs stay in place with the vavle cover.
7. Remove lower manifold, after all the bolts are out you can roll the manifold out, as standing in front of the vehicle you will roll it towards you to clear the rear valve cover, it will come right out.
8. Get a 10mm wrench and losen all the back rockers and remove the pushrods, now you can remove the rear gasket
9. clean all surfaces
REassmebly
1. Use silicone and put a small dab under the gaskets for the rear valve cover, and install the rear gasket. then install the pushrods and tighen the rocks on the rear
2. Instal front gasket and pushrods and rockers. apply silcone to block
3. Take the lower manifold and cearfully roll the manifold done into place as you removed it, if you do it right the back corner will just touch the silcone and be inplace, then tighten all the lower bolts and then the rear valve cover bolts. and contuine in reverse order as you took it apart.
4. After the engine is back together and running put the coolant in the engine.
these is a small trick for this too, get an old radiator cap and drill a hole in it and put a funnlel in the hole very tightly and get something to fit the in the hole to force coolant into the enigne, fill the resivor and open the bleeder and then fill the funnle and force coolant into the engine untill full. and your done.
hope that is a helpfull at making this job aneasy one, sorry for the bad spelling i'm not a very good speller
REassmebly
