I took my 1990 Grand Prix STE with a 3.1 MPFI off the road to fix a MINOR surging problem. Occasionally, when I was coming to a stop, the car would surge until it was stopped, and also, SOMETIMES when I would take off from a stop, there would be a hesitation, then it would clear up.
I replaced my DIS (it was old, and one of the connectors was messed up anyways), my IAC, MAP, and the fuel rail and injectors. I had some issues with getting it to run, but finally today, I got it to start up, and idle like it should.
As I was cleaning up, I noticed what sounds like a SLIGHT misfire, so I decided to go for a test drive to make sure that the car was running right (and also to calibrate the compass since I had the battery disconnected)..
As I was leaving out the car was hesitating, misfiring, and surging REALLY bad. It would surge and hesitate all the way into second gear, then it would clear up, but if I got on the gas, sometimes it would hesitate, then clear up, but when I took my foot off the gas, the car would keep accelerating.
Any idea what I should check on this? I have been trying to fix a similar problem with my 1988, and seeing that BOTH CARS are doing the SAME THING, I feel that I am just overlooking something simple with both of them (the 1988 is the one with the 3100 MPFI).
