Is there any way to test and see if it is my fuel pressure regulator? If there is and that is it is there any way to fix that or do i have to replace the whole thing?
Fuel pressure regulator
Easiest test without tools would be to remove the vacuum line on the regulator, then run the fuel pump (ign on, engine off, or find the fuel pump prime wire and touch it to the positive terminal underhood) and check for fuel leaking out of the vacuum port.Brian
3400 SFI V6, 4T60e
yeah that's the same symptom, the fuel would travel thru the vacuum line to the TB.Brian
3400 SFI V6, 4T60e
