I have the 94 style single wire sender for the gauges temp sender. It seems to loose signal and drop the gauge temp to cold on and off. It was going back and forth from working to not working when I hammered it, so I thought it might be a short in the wire on the pigtail or on the engine harness side...
But then it did it just sitting there.
1) So do you think it's the wire or the sender is going out?
2) How much coolant will pour out? Should I drain the radiator?
Afterthought: I thought about putting the 3 wire CTS in and putting the wire after the pigtail through the fuel injector harness so it would all come out to the 3 wire connector nice like factory instead of having an extra random wire lengthened. But I don't feel like taking the plenum off now...
