I have a fiero with a 3400 installed running it with a 7730 ecm. The chip has a good tune by Ryan Hess. I have put about 300 miles on it so far with no problems other than i have a bad idle issue. i was also getting over 33 mpg. I was driving normal down the road when out of nowhere the engine started gasping for air (could hear loud sucking from air intake). Then the engine stumbled and revved way up to over 4500 rpms and then went to 5500 when i turned it off. Now it will only rev up to the highest when i turn on the car. I checked all the vitals like if any water lines fell off, all vacuum lines, oil, unpluged battery and plugged it back in and did a quick look to see if any electrical lines looked melted. everything that i looked at was normal so i am kinda stuck. any help would be spectacular. Thanks
Blake Tate
Blake Tate
