Anyone know function of Y-Guide between timing chain?
2.8 Timing Set: Y-Guide
You mean the tensioner?Originally posted by 85_Olds_Ciera View PostAnyone know function of Y-Guide between timing chain?
It is just a damper in case of any slap that may happen. You need it so don't remove it. If it is broken, which is common with age, then you need to replace it.1993 EXT. CAB, 3.4L V6 TBI, 5spd manual. Sonoma
I replaced it...sides of it were wore down, and upper right corner was "chipped" off...maybe when OEM Cam Gear was shedding nylon teeth. GM-Denver only had five left in stock...$26.00.Originally posted by betterthanyou View PostIt is just a damper in case of any slap that may happen....
On small-block chevy, you don't see a damper.
I would think centrifugal force would cause chain to go outward...but based upon the wear pattern, the chain does rub on it.
For $26.00 US, I'll pay the price...there may be aftermarket Y-Guides...I never looked....it might be done, but one would have to be familiar with type of rubber compound used, and what shapes are available.Originally posted by barrok69 View PostI wonder how hard it would be to actually make a tensioner. It would probly improve chain durability.
If I didn't toss it, I'll take a photo of it today...
no i'm talking about an actual tensioner, not a guideplate. something that would maintain chain tension... like the tensioner on the serpentine belt.Originally posted by 85_Olds_Ciera View PostFor $26.00 US, I'll pay the price...there may be aftermarket Y-Guides...I never looked....it might be done, but one would have to be familiar with type of rubber compound used, and what shapes are available.
-=ЯoB=- 3400 3spd Z24 ---167Hp, 193Ft-Lbs @ the wheels
14.99@91.33mph
1987 3.8 GM had a spring loaded chain tensioner on it...something like this might be converted...but, one might want to know why they (engineers) didn't use a spring loaded tensioner on 2.8 motor....is its "slap" more "violent" during start/stop cycle?Originally posted by barrok69 View Postno i'm talking about an actual tensioner, not a guideplate.
All the guideplate would do is kept it from slapping inward....but on SBC, they don't use them on stock motors...don't know about hot-rod motors (high rev motors).
I only know GM-Denver had five in stock...I don't know what that means for GM, or for aftermarket builders.Originally posted by ForcedFirebird View PostI think it might be an easy mod to make the dampener into a spring loaded version.
On mine, the rubberized sides were worn down...I didn't see what held them on...
It's been too cold around here to work on cars, but maybe next week, I'll look for the one I took off.
You don't see it on a small block because the cam and crank are much closer together. Meaning a much shorter chain.Originally posted by 85_Olds_Ciera View PostI replaced it...sides of it were wore down, and upper right corner was "chipped" off...maybe when OEM Cam Gear was shedding nylon teeth. GM-Denver only had five left in stock...$26.00.
I would think centrifugal force would cause chain to go outward...but based upon the wear pattern, the chain does rub on it.1993 EXT. CAB, 3.4L V6 TBI, 5spd manual. Sonoma
Meaning a much shorter chain length between the two gears...agreed.
Chain "slap" increases with longer "free space" (distance) between gears.
On a motorcycle, you can see/hear this chain slapping clearly with a "loose chain."
Never have seen what the chain's "drive side" looks like when in motion...but I suspect it "drifts" in the vertical plane.
But on a motorcycle, most chain motion tends to be an "uniform" motion...whereas with vehicle engines, its more like a continuous "jabbing" motion.
Since both sides were wore, then chain slapping is happening to some degree on both sides.
