get a used PCM
no start after lim
Thermostat housing, under the throttle body. FYI You should probably get new plugs while you are at it as any carbon in spots might cause it to misfire with this ignition system...The cold weather will just aggravate things more.Lorenzo
could try shooting some choke cleaner directly into the throttle body and see if she'll fire that way. that would eliminate the fuel system. have you replaced the crank position sensor?Last edited by torq455; 02-15-2008, 02:53 AM.Andy
fastest 1/8: 10.19@ 67.17
fastest 1/4: 16.16@ 82.70
I don't have a puller to get the pulley off. she wont go on starter fluid. can't get fpr off lol stuck.
i just took a small sample of gas and it was soo full of gas it poured out!
its got to be an injector/fpr im gonna change the whole rail!Ford Guy says to we " keeping up with that General Maintenance as you drive a gm?' I say to him well when you found on road dead tomorrow, I'll be in the next province.
it's all together just waiting on a dead battery. it seamed like only 2 injectors where firing and it had low fuel presser!Ford Guy says to we " keeping up with that General Maintenance as you drive a gm?' I say to him well when you found on road dead tomorrow, I'll be in the next province.
