ok, was doing some maintenance on my DD 3.1 Lumina, and i have to do a thermostat on it (stuck open) and i was trying to pull the intake piping off (probably never been off in 10 years) and ended up having the plastic pcv hose going from right before the TB to the rear head by the ignition module shatter on me (it was a wee bit cold out so....) but as far as i can tell, no auto parts place seems to carry that hose. they have the one going to the PCV valve, but not the one i need. Any idea where i can get this or does anyone have a P/N i can use to get a local place to order it?
Also, is there any EASY way to replace a t-stat on a 96 3.1? Im also wondering how much coolant will spill out when i pull the t-stat housing (if i can get at it). the way it looks to me, i have to pull the TB off to get at the housing and even then, its a wrench job as a socket doesnt look like it will fit between the housing bolts and the crossover pipe.
btw, thanks in advance
