Ok, so I did a compression test on my 3.1 today because I was curious to see what its at now that I rebuilt the engine with thinner head gaskets, plus it looed like someone already had the heads milled down!!
All cylinders were between 175 psi and 180 psi....
Does anyone know what that is in ratio form??
If you are running a 3.1 and using the iron head gaskets your CR should be around 9.37:1. You may not have valve to piston clearance problems, but like ForcedFirebird says you really won't know until you take it apart or over rev it and something very bad happens. I agree with Forced also on the fact that your quench values will be less than ideal.
