Hello All
Some of you may remember me from last year with the 1997 Malibu 3100 to 3400 swap. (see link for more info about my setup)
http://60degreev6.com/forum/showthread.php?t=37569
First off the car still runs and drives great has lots of power and is a lot of fun to drive. The only issue I have with this car is a rough idle. It is not to the point where the car dies and the RPMS are always steady at around 650+/-. The 3400 is a stock 2005 motor but the best way I can describe the way it idles is that it feels/sounds like it has a huge cam in it. Everything else is still stock on the car including exhaust, intake, etc...)
I still have all electrical parts and crap from the 3100.
HERE IS WHAT I HAVE TRIED SO FAR:
1. New Plugs (NOT the old 3100 plugs)
2. Changed the coils and wires (the old ones from the 3100)
3. Checked for vacuum leaks and can not find any.
4. This 3400 has the 3100 fuel injectors in it. (I have no way to tune the stock 1997 - 3100 computer for the larger 3400 injectors.)
5. I DO get a code that tells me I have a misfire on cylinder 2 about every 100 to 150 miles that goes away on its own after a day or two.
6. I have sprayed the entire electrical system down with water to try and find a bad wire, connector or short and this makes no difference at all. (Weather conditions do NOT seem to matter either.)
This seems to be SLIGHTLY worse when the motor is warm or after driving it hard. I have a few thoughts but lets see where this gets me...
Any replies welcome... Thanks in advance.
Steve
Steve
