I have a 94 GP with the 3100 in it. I have been having problems starting the car recently, which was overcome by turning the key back to the AUX. position or by pushing in on the lock cylinder as I turned the key forward. Didn't happen all the time or with any rhyme or reason, just happened. Now it does nothing. No starter sounds, no fuel pump sounds, no dash lights, dome light goes out and stays out, no radio, nothing. Basically, after trying to turn it over, I lose ALL electrics. I replaced the $100+ ignition no change, checked all fuses, checked both battery cables and cleaned very minor corrosion off, pulled starter off and had checked with solenoid and they worked. I'm thinking possibly C.P.S. or neutral safety switch next. Any help please, I'm 400 miles from home stranded, and need to get home ASAP. Thanx in advance.
3100, PLEASE help
well if you are not getting anything out of the car when key is turn forward i would be leaning toward the ignition switch.. It's mounted on top of the steering column.. I believe you already replaced that.. Did you check the under the hood fuses next to the radiator cap and the overflow tank?? The fuses are quite large!! Did you check the AUX terminal for corrosion too?? Hoping i can help ya out..Robert
[FONT="Fixedsys"][SIZE="3"][COLOR="Red"][B][I]96 Grand Prix SE 3100 202,000 miles
New Rebuilt 3100
New Rebuilt 4T60-E
Exhaust
Drilled/Slotted Rotors[/I][/B][/COLOR][/SIZE][/FONT]
[FONT="Fixedsys"][SIZE="3"][COLOR="Red"]95 Grand Prix GTP 177,000 miles
White
3" Magnaflow Catback
94-96 Hi-Po 5 Stars on 245/50/16[/COLOR][/SIZE][/FONT]
90 Pontiac Turbo Grand Prix
5 Speed Swapped
127,000
Spec Stage 3 Clutch
230,000 mile Getrag 282
Emissions Deleted
Brand new Engine 1,000 Miles
Fully Custom Built car
Hmm.. Sounds Strange.. So nothing happens when the key is turned? Its like if there was no battery in the car??Robert
New Rebuilt 3100
New Rebuilt 4T60-E
Exhaust
White
5 Speed Swapped
127,000
Spec Stage 3 Clutch
Emissions Deleted
Have you trid jumping the car?? Highly doubt it but its only worth a try but possibly a bad battery.. It can't hurt to try though.. I'll Think about it more and see what i can brew up.. But you got me stumped too..
Robert
New Rebuilt 3100
New Rebuilt 4T60-E
Exhaust
White
5 Speed Swapped
127,000
Spec Stage 3 Clutch
Emissions Deleted
Are you sure everything was connected properly to the ignition switch? If you have power in any other position of the IGN switch, and everything goes dead when you try to start, I would lean towards that more than anything. Here is a diagram for a 94 Beretta starting circuit, which should be fairly similar to yours...[CENTER][color=red][b]-Brad-[/color][/b]
[size=2][b][color=blue]89 Mustang : Future 60V6 Power[/b][/color][/size]
[SIGPIC][/SIGPIC]
[size=2][color=blue]Follow the build -> [url]http://www.3x00swap.com/index.php?page=mustang-blog[/url][/color][/size][/CENTER]
Okay. A friend of mine just went through what sounds like the EXACT SAME THING.
For him, the NEGATIVE BATTERY CABLE was messed up, but what I would do is check to see if your UNDERHOOD ELECTRICAL CENTERS Are even getting power.
The MAXI FUSES should have power at all times.
Pull out 1 or 2 maxifuses, then use a voltmeter, or multimeter to see if you are getting power at all. His Grand Prix was an older one, but it was the PASSENGER SIDE fuse block that was not getting power, and just like yours, he would turn the key on and NOTHING.Taylor
1998 Lincoln Mark VIII
[IMG]http://i174.photobucket.com/albums/w86/riven2129/newestsig1.jpg[/IMG]
