Any thoughts on what could be causing an intake backfire? #1 cylinder seems to be the culprit. I've done a compression test and have 160-170 in all cylinders. I tried moving the coils around to see if it might be ignition related, swapped plugs and tested the plug wires and no change. The engine is missing and backfiring regularly as #1 cylinder fires. Fuel pressure is about 55# and holds. When I pull the plug wire off of #1 it still misses (of course) but the backfire is gone. I have a 3.1 hybrid with a 2001 3X00 top end and a Delta 260 regrind. It was running great, I came off the freeway and it started acting up at the end of the ramp. Any thoughts are appreciated.
-- Scott
-- Scott
