96 Ciera, 3.1. When diassembling the heads, found a bent valve and it's seat sticking out 1/8 -1/4 inch from it's proper position. Can I just carefully tap it down to where it's supposed to be? What holds the seats in position? Appreciative of any advice. - Scotty
Bent valve, seat misplaced on 3.1
i woudnt because you can do more damage to the head like mess up the valve guide or even crack the head...id just buy a new valve..what holds it into place is the valve spring holding the valve shut..and the seat just seals the combustion chamber...00 turbo'd gagt msd 8.5 mm wires,ngk tr-6 plugs,42.5lb inj,65mm tce t.b,ported upper intake,ported lower,ported heads,copper headgaskets,headstuds,160 stat,ls6 valve springs,st3 turbo cam and pushrods,turbo manifolds,custom 'y' pipe,3in open d.p.,dhp powr tuner,garret t3 60-1 .63 turbine,70 compressor,6 pounds of boost...STOCK CAM,STOCK 103XXX BOTTOM END...2.041 60',13.683 @ 100.34
99 gtp 4in. F.W.I...180 stat..headers...104's...msd8.5's..1.9's...3.4 pulley...cat & res./
