Hey everyone and thanks for the help in advance. I have an 87 firebird with about 345,000 miles on it. It has been an awesome car and I couldn't have asked for a better experience with it, virtually no engine problems whatsoever. I did have a trans problem and had it rebuilt. Whenever I was installing the transmission I decided to replace the flexplate since I had been hearing a light ticking noise from rear of the engine. When I was taking the old one off and putting the new one on I noticed that I could rotate the crank about 1 to 1.5 inches on the outer circumference of the flexplate. I dont know how many degrees this is exactly but it has me a little worried. Everyone that I talked to thinks that maybe I need to check the cam chain. I imagine that it is pretty well stretched since I bought the car at 140K miles and haven't done anything to it since then.
BTW, the ticking noise can not be heard above 2K rpms, and if you blip the throttle just a hair it doubles in frequency for a sec. I put a stethescope all over the engine and the loudest seems to be on the fuel rail. Thanks!
I went thru this same repair earlier this summer with my son's cars engine. You'll need to pull the fuel line off from the fuel rail and back off the retaining bolt holding the injector to the intake, slip out the injector from the intake & take it with you to a shop to get the O-ring. You'll have to pull the line off the engine anyway to change the O-ring. I wouldn't try to bend the line trying to get the O-ring out, you may break the line and they are not too common to find anymore. The o-ring is a neoprene item not rubber.
