I just replaced my head gasket and had the heads redone on my 97 Monte.when I went to start the engine for the first time it just cranked,No start,The engine sound like it wasnt getting any compression.So I backed off the rocker arm bolt and the engine started up, but had alot of valve train noise.The rocker arms keep getting loose.
Can anyone tell me why my rocker arms keep getting loose when i back off the bolt.When I Tighten down the rocker arm bolt all the way then the valves stay open and my engine wont start.My buddy at work told me that he thinks the machine shop didnt cut the valve stem down when they grind the seat.This for a 3.1L engine and as I understand it the valves are none adjustable.Any help would be thankful :P
