I just swapped my throttle to a 56mm. Once installed and started it had a lopey idle until alittle warm and runs at 150-200 rpms higher. Can anyone help me out about to pull the rest of hair out.
96 lumina idle problem
Did you use your original sensors or the ones that came with the 56mm TB? I have seen people have issues before similar to this, and they went away when the original sensors were used.-Brad-
I used the original sensors. When i removed original sensors from the 52mm the IAC was very dirty and was cleaned. The car today when started had a lopey idle and once warmed it stopped and idled at about 900 rpm. Do you think i need to adjust the idle screw. The parts from wot-tech and pretty sure i was set since i'm sure they done this a million times before. Before i installed i made sure the throttle was snapping back shut and i didn't really see no gaps.
