As the title says, the 3.1 seems to be running terribly rough.
The vehicle hasn't been driven much in the past two years, probably only had 3000 or 4000 kms put on it since October 2007.
A couple weekends ago I took it for a fairly long trip - 800+ kms over two days - it seemed to run alright, the odd barely perceptible miss here and there.
Tonight, I took the car out to see a movie. I was driving fairly fast on the highway, and it seemed to be running alright... as I slowed down, however, it started to miss / run rough more and more. Parked at the theatre, watched the movie, came back out and it started fine, but runs rough even at idle.
I limped it home with varying levels of rough running. We'd go around a corner and it would seem to run alright for a few seconds, then back to rough. It seems to run worse at low throttle settings / RPM. Condition is the same regardless of gear selection - even does it in neutral. There doesn't seem to be any regular pattern to the missing to indicate a single cylinder being at fault. The check engine light is not lit. I do have an OBD 1 cable and some assorted software available for pulling data from the PCM.
I haven't started any hard troubleshooting yet - I just wanted to pass it through here to see if anyone has any ideas. Corroded spark plug cable connection? Bad DIC module? Fuel injector? Fuel pump?
Any advice or suggestions on how to troubleshoot it would be appreciated.
Thanks!
Thanks!
