I recently bought a 94 Sunbird 3.1 with 110,000. It was sitting for about a year. It ran a little rough but just at idle and kinda choked at 55-60 on a steady cruise. I checked the plugs, carbon fouled but recently put in, still had anti-seize on them. The plug wires I replaced they spec'd bad. New IACV, I cleaned the plugs re-installed. I get 12.8mpg. Major problem, no Trouble codes and the computer showed nothing stored. The fuel pressure is steady at 40 not running and it drops slightly with vacuum applied to the regulator.I ran a can of sea-foam in the gas tank to clear up, new fuel filter and I ohm tested the injectors all at 12.6-12.7V the harness is steady at 12.0V. Still haven't ruled out plugged injectors. Coolant temp sensor checked ok, and the crank sensor checked ok, so I have the knock (doesn't ping anyway) the TPS and possibly suspecting the coils, or a plugged catalytic? Any input appreciated.
1994 3.1 Bad mileage, fouled plugs.
Tags: None
If you hear a knock on the highway going WOT and it's still slow, the that could be a clogged cat and the backpressure opening the spring loaded downpipe flange and it snapping closed... My friends Impala did that when his cat was clogged.sigpic
Ok, I replaced the injectors and rail assembly, still runs bad, swapped out the Module and all 3 coil packs, no change. It runs extremely rich and I just can't seem to stop it. Possible the ECM is fubar'ed? I do have a small water leak on that side of the firewall, but it seems to run behind the sound deadener, but who knows it if ever came into contact with the computer. So far I have done Module, coil packs, wires, plugs, injectors, rail, fuel pressure regulator, IACV, tested the crank and temp sensor and catalytic. So I have the TPS, O2 sensor, harness and ECM left. Any other guesses? I'm stumped, just gonna swap out the rest of the parts and hope for the best.
