Hi all,
Im having a tough time figuring this one out.A buddy's 91 S10 with the 2.8 TBI,
the injectors will not fire any gas.We did a spark,fuel pressure and pump tests and everything passes GOOD.We tested the pressure and double checked it all.Its getting plenty of gas to the TBI.
Engine cranks over just fine and the car will only fire up if we pour some gas down the Tbi.Then it stalls when the gas is gone,just a few seconds.
The injector harness clips is getting power but the injectors wont spray any gas.
A few days back when problem first started,we poured gas down the tbi and the engine fired up and THEN the injectors started working again and the engine kept running.Then,a week later,the injectors wont fire anymore.
You have any ideas whats causing this problem?Is there a relay that is supposed to signal the injectors to fire gas?Btw,all fuses checked out good.
Thanks for any links or ideas.
