Which Distributor for 2.8L V6 (1984)?
I have a 1984 Firebird with 2.8L V6. It has an ECM which controls carb mixture and distributor ignition advance. After 200k mi - the original carb is tired and the emissions equipment has simply gotten too tempermental to hold a tune. I have a replacement VaraJet that I'll be rebuilding out of an S10 which is a bit simpler than the original.
In addition to installing the carb (and removing the check engine bulb) I believe I'll need to replace the entire distributor with a vacuum advance version.
If so any recommendations on which distributor I should go for?
A distributor from a mid 1980s S10 with 2.8L also has vacuum advance - should I go with one of those?
The car/engine is stock, dependably gets 25mpg currently - just want good overall driveability and gas mileage.
thanks.
thanks.
