I finally got the 3400 into my 95 GA, but it's been sitting so long it's frozen up. What can I do to get her to turn over?
Frozen 3400
Frozen 3400
To Many Mods To List, Check It Out At
Joe\'s 95 GA GT
3100 Best ET : 15.389 @ 90.48Mph
3400 Best ET : TBD
My Cardomain SiteTags: None
Can you turn it over by hand via the crank bolt and a breaker bar?-Brad-
Depends on how long you want it to last. You need to find out why it's frozen. If it is a frozen ring thing and you break it loose, you take a chance of scoring walls from rust particles. Then you burn oil. Personally, I would never break a locked engine with a breaker bar, and then try a startup. If you do though, soak cylinders with a combination of trans fluid and WD-40 first. Leave it a week. Expect a LOT of smoke when it fires. A sitting engine usually locks up from the valves that are open and gathering moisture.If you are driving a Chevy, everything else, is just a blur. 3.4 Carbon Footprint.
And I have to add this. Frozen rings don't always mean just in the cylinder. They will lock on the piston. It's a chemical thing. Aluminum minus oil plus steel plus moisture = oxidize. That's aluminums word for rust. Ever take a steel bolt out of an aluminum part? (the green stuff) If your rings are locked you have to rebuild. Of course you might get lucky. Did it on several 350s and 283s.If you are driving a Chevy, everything else, is just a blur. 3.4 Carbon Footprint.
Yea I agree you can WD40 and penetrete lube the hell out of the rings but it will still be a hack job. If you want a reliable runner then you need to rebuild.
However it may not be the rings that are bad.1993 EXT. CAB, 3.4L V6 TBI, 5spd manual. Sonoma
