Many of you know me to this forum, the 96 GP turbo build.
I have a strange issue with the engine and it is really hard to figure out.
First, the symptoms I noticed today after a long drive.
The ECT read 240 when I decided to shut it off. It became hard to start later and ran a little rough. DTC was a cylinder misfire present. No other DTC's except a lean condition but that popped up after the misfire. That I understand how it happened. Absolutely no knock during that as I was scanning.
When it starts it runs chuggish for a few moments then evens out and idles just fine. I can not find any coolant loss and the exhaust isn't smoking badly. But I can feel an occasional misfire when driving it, not a bad spark plug cable kind of misfire, just an annoying faint misfire only under load. Again, this is only when it is warmed up, and not an OL/CL issue otherwise it would start sooner. It happens after a good drive kind of warm up. And the plenum is hot, not too hot where I can't touch it, but hot. Not sure if that would matter.
Coolant levels are the same, no bubbling. Oil levels are good and stable.
Here is a list of new items to rule out.
Spark plugs, cables, coils. Radiator, pump, hoses, ECT Sensor, thermostat. Heads (complete), gaskets, o2b1, injectors, battery, cam/crank sensors. Oil, filter, flush.
Maybe I am just over reacting and the car is not tuned so it runs hotter then normal. But what is causing the stumbling at start up after a good drive?
Coud this be a failing ICM?
Man, I am perplexed and disappointed deaply. After all that hard work/money and I have this issue to deal with.
edit: btw, I paid extra special attention to the gaskets install. Everything went as it should. All bolts torqued just right in the right order. Thought I'de throw that in the mix.
edit II: Went out and she started right up. Though, the exhaust is smoking a little. But with the weather, it could easily be condensation in the exhaust lines. I know cars can smoke some at start in colder weather like what were having here. And now it idles great. But I bet if I drove it around for a while it would do the same crap it did earlier. We shall see, I'm going to drive it around a bit. I'll report back.
edit III: yup, same crap. When warm the exhaust is clear. But I can not figure this stumbling at start up when it has been driven around. ECT is ok now, it was an idle situation as the idle was high and now I have it set to 800. I guess even in cold weather an idle of 1200 can heat up coolant fast. Plus, the fans were set at a temp way to high, 250. Is that a standard Lumina setting? I put them at start 220, end 200. Fan II is 20 deg higher.
Could a bad fuel pump do this? The pump is 108k miles.
