This is a 1994 Buick Century, 3.1L V6 VIN M. When I first got the car, the coolant overflow tank seemed to have a high quantity of oil in it. The thermostat was either intermittent or stuck, because the car would bounce between fan cycles pretty quickly.
That was replaced, and the coolant system was flushed. Over the past few days, I have noticed that I'm losing coolant very quickly, and the oil in the rocker cover is very thin, and dead black. I also noticed that the car's running a bit rougher than before, I lost almost all engine power, as I would WOT the car to get to highway speeds and I had no acceleration at all, and the lack of power was also apparent from idle.
I started noticing an oil leak in my driveway as well. I am currently working on replacing the Lower Intake Manifold, hoping that the issue lies there and not further inside of the engine. The engine has overheated before from abuse, but there were no issues that had arisen at that time.
I am currently having a problem getting the Lower Intake Manifold off, though. According to all books and Mitchell OnDemand, the Power Steering Pump should just pull right out after being unbolted. However, the reservoir contacts the LIM when being lifted, and therefore cannot be pulled out to access the last manifold bolt. I need suggestions on how to go about getting this PITA moving again.
I rented a PS Pump Pulley kit, as I had originally thought maybe the extra movement with the pulley being removed would give me the angle required to remove the pump. However, after further review, it appears that this may end up causing more harm than good. Does anyone have any ideas? Any help is greatly appreciated!
