When the pump primes at key on it builds weak pressure then drops it's pressure in seconds. The engine will want to run but stumbles and stalls as fast as the pressure drops. This is what I ruled out so far.
The car did sit outside for 6-8 months. Did a manual swap during that time. It took some time but everything went well enough. No accidents or damages along the way. My fuel fill cap has a lock on it so I rule out general vandals. The EVAP lines are disconnected though, but the engine operated fine like that in the past.
CHECKS
- No smell of fuel when the closed fuel system is primed
- No sign of fuel leaking any where along the fuel lines
- Checked Injectors and no leaking at the rail or the nozzle
- Checked with a known good FPR, no change
- Fuel Filter is clean and free flowing
- Fuel is flowing well from the FPR port when pump is primed (when I had FPR removed)
- Fuel pump makes a normal healthy sound (opinion, could be wrong)
- Tank has 4 gallons, fuel gauge registers above empty and car is level
- The Fuel Pump is only 1-2 years old w/ no more then 2,000 miles on it
There is a hissing noise at the fuel rail. But no air or fuel is seen leaking. Not even out the FPR. It is really strange, and I will say there is NO fuel leaking any where outside the fuel tank. So why do I hear hissing at the fuel rail?
I want to say it is the Fuel Pump or the Check Valve (still replacing the pump if so) but wow, not many miles it lasted. Can stale gas ruin a pump?
Can anyone else tell me other possibilities (if there are any)?
Cause at this point it looks like a fuel pump replacement but dang-it, I did that grueling task not too long ago....... /sigh
Please Help
CHECKS
Please Help
 It is a dash gauge from Glowshift but it should work just fine.
