Ok guys, I recently finished the break-in on my engine and last week I decided to do a compression test on it. Numbers are very low. Cylinder pressures range from 100 to 115
. I used dino 5w-30 oil with 3oz of Lucas Zinc Plus additive on every oil change during the 3000 mile break in period.
I think the rings are shot. The engine it's a 2.8 iron head with forged slugs std size running on 6 pounds of boost. I used Hastings moly rings on this previous rebuild.
My question is should I use moly rings again or regular rings on the next re-ring? I have read that moly rings shouldn't be used on worn cylinders. Anyone has more information regarding this? Bear in mind i'm going to do the honing myself so I won't be able to check cylinder roundness.
I already bought a set of Speed Pro Moly rings (E-411K) but I'm thinking of using the non-Moly version (E-411X) from Speed Pro. I want to be able to use this engine reliably while making good power until my next build. I'm planning to do a 3.2 DIS setup with the 7730 ECM for next year.
Also, should I break-in the rings with the turbo hooked up or without? How do guys with boosted engines perform the ring seating procedure?
. I used dino 5w-30 oil with 3oz of Lucas Zinc Plus additive on every oil change during the 3000 mile break in period.I think the rings are shot. The engine it's a 2.8 iron head with forged slugs std size running on 6 pounds of boost. I used Hastings moly rings on this previous rebuild.
