Alright, so, my younger brother has a 1992 Camaro RS, 3.1 V6, automatic
What happened was this, he was going up the road, car started to loose power and would outright stall at idle. Then, once it got hot, it got to where it would not start at all. Worse case scenario 'cause he just got a job, middle of the pay period so we can't really afford to put gas in my fathers '86 Oldsmobile Custom Cruiser. Basically if we don't find a quick fix, we're screwed. He's had the car for about 380 miles, and about a week and a couple or few days since he bought it. He put a tank of gas in it, not cheap stuff, Shell gasoline, which around here is good. Now it has become a red lemon with a bad clearcoat.
After some looking, my father and I discovered that no spark is being generated, the fuel pump seems to be functional, sending fuel, everything seems good until the engine gets to the normal operating temp of around 180F. Then, the car sputters, and stalls after a while, it will not start until ti gets cold again. Occasionally it will send a spark, but, it spits and sputters, doesn't catch.
What I do know about the car is this, the previous owner bypassed the fan sensor and jammed a wire into the ignition fuse, so the fans come on when the ignition is on, and, the previous owner somehow bypassed the coded ignition key system, I haven't a clue how. Also, the engine was resealed, it has a new oil pan, and the transmission was replaced. It would be a shame to have to give on it at this point. Though we did none of this work too it.
We have tried the "paperclip" in the OBD plug to flash the SES light, no luck. Just keeps flashing 12 three times which means nothing is wrong.
So, basically, if anyone has any idea's, tell us. We do not want to go through the whole "Replace these parts and hope for the best' mess. We simply cannot afford that, financially, or, the time it would take.
On a side note, we where going to pull the coil and dis from another 1992 Camaro we have that is going to be sold soon, temporarily, until we saw the nightmare that is. We did try the computer out of that other Camaro just for the reason of running out of idea's. Same mess, no go. A friend of mine said it might be a crank sensor, had another person tell us it could be a whole load of things. I expect the same answer here, but, I'm remaining hopeful for a solution.
Thanks in advance for the quick response,
-Ben
-Ben
