LIM to block seal 3.1 Aluminum head
  • LIM to block seal 3.1 Aluminum head
    I am going to go out on a limb here and say the LIM to block (valley) seal front and rear is only formed by silicon gasket compound. I’m I correct or do I need to look for more gaskets? Anyone with a preferred brand to use? Larry
    All the gasket sets I've had came with a small tube of black RTV sealer for those spots. Just about any high-temp RTV will work.
    1995 Grand Am SE
      The 3500s use an actual gasket, but all other engines just use RTV.
      [CENTER][color=red][b]-Brad-[/color][/b]
      [size=2][b][color=blue]89 Mustang : Future 60V6 Power[/b][/color][/size]
      [SIGPIC][/SIGPIC]
      [size=2][color=blue]Follow the build -> [url]http://www.3x00swap.com/index.php?page=mustang-blog[/url][/color][/size][/CENTER]
        I thought so, but just checking. Looks like the way to do this is to tighten the 4 bolts that pull the LIM down and then do the 4 corner bolts that pull it towards the head. I saw the torque specs some place. Larry
          RTV varies
          Black is the standard, many people use copper color because of a higher heat capability (not necessary for the LIM application) and then their is gray. Gray is used by many OEMs for valley sealing because it is a little stiffer and has better resistance to antifreeze. Check the labels.
            clean the surfaces really well, i typically use black or copper.. never had a problem with either. 4 centers first then the 4 outers.
            same sequence for a gen 2 or a large port 3x00
            [url=http://www.v6z24.com/registry/SuperDave]1991 Z24, 3500/5 Spd. 275WHP/259WTQ 13.07@108 MPH[/url]
            [url=http://www.v6z24.com/registry/superdave/5]1989 Camaro RS, ITB-3500/700R4. 263WHP/263WTQ 13.52@99.2 MPH[/url]
            [url=http://www.v6z24.com/registry/superdave/6]1972 Nova 12.73@105.7 MPH[/url]
