I'm at a loss on what to do. First here is what I'm working with:
LX9 swapped into 1991 Grand Prix with Getrag 284
External crank trigger OBD I ECM, which has gone through a lot of tuning
CPS is set at 0 degrees timing (the crank trigger is adjustable)
3400 exhaust manifold
New 3 way cat converter, 2.5" pipes, 97 Grand Prix GTP stock mufflers
3400 throttle body and fuel injectors
43 psi fuel pressure at WOT
Stock heated LX9 o2 sensor
How it runs:
Idle is smooth on the tach. At idle engine has a bit of a vibration to it though, not enough that I'd call it a shake, but it let's you know its running. In gears 1-4 under 2500 rpm feels like it's missing some torque but its not awful. In 5th gear it shakes pretty violently at anything under 2500 rpm. WOT performance isn't terrific, but not awful and I'm sure the old school 3400 exhaust manifolds are hindering all out performance. But that is not my main concern, rather the poor low end torque and the shaking motor. Driving normal above 3000 rpm the motor runs great and torquey, it cruises beautifully at 45 mph in 4th.
I've gone over the entire fuel injection wiring a few times and can't find a problem. Its been through countless back/forth tuning. It holds good vacuum at idle, roughly 40kpa. I gave it new plugs and wires. The old plugs looked perfect in color. I plugged an exhaust back pressure gauge in the o2 sensor port and the back pressure is negligible. I'm at a loss on what to do and looking for any advice.
How it runs:
