Hey all, I am working on my 1988 Olds Ciera, with 2.8MPFI engine.
I've been working on a tune and noticed the ECM reads about 10°F cooler than the instrument panel gauge.
At speeds above 70 mph, the ECM reports about 215°, but the dash gauge goes into the red. I have a 180° thermostat and fan control temps of 195 on 190 off.
Under all other conditions (idle, stop & go, with or without A/C) the engine runs about 195 on the ECM but the dash gauge most always reads at 220 or higher.
The previous owner had just changed the sensor for the dash gauge, and it appears the instrument cluster its self came from a junkyard.
I remember reading a long time ago that the location of the gauge sensor (in rear head near exhaust port) is unwise because it causes a false high reading.
Should I move the temp gauge sensor to a water port in the LIM (near ECM sensor)?
Thanks in advance for any input. This is the first GenII aluminum head engine I have owned.
Sincerely,
David
Sincerely,
David
