Here goes, got a 98 Montana with a 3.4 throwing a P0300 code. It idles rough and no other codes are thrown. I have so far:
-Plugs are new AC Delco 41-921 gapped @ .06
-Plug wires are new
-Ohm tested all injectors (all the same @ .012)
-compression tested all 6 cylinders and got 150-153ish all cylinders
-Used a spark gap tester to check coils and got a strong blue spark from each coil tower
-I also replaced the LIM and UIM since I had the car half way apart before putting back together.
-no unusual noises
-raining today and I can smell the 'rotten egg' smell from exhaust
Here is some sample live data, all at idle parked. If I posted all 60 snapshots you would notice the spark adv stays generally around 20-21 but goes as low as 18 and jumps as high as 25
Live Data
DTC_CNT 1
FUELSYS1 CL
FUELSYS2 N/A
LOAD_PCT(%) 3.9
SHRTFT1(%) 26.6
LONGFT1(%) 21.9
MAP(inHg) 15.9
RPM(/min) 656
VSS(mph) 0
SPARKADV(°) 21
IAT(°F) 81
MAF(lb/min) 0.849
TP(%) 0.0
O2S B1S12--B2S----
O2B1S1(V) 0.715
SHRTFTB1S1(%) 26.6
O2B1S2(V) 0.910
OBD OBD2
DTC_CNT 1
FUELSYS1 CL
FUELSYS2 N/A
LOAD_PCT(%) 3.9
SHRTFT1(%) 26.6
LONGFT1(%) 21.9
MAP(inHg) 15.9
RPM(/min) 735
VSS(mph) 0
SPARKADV(°) 24
IAT(°F) 81
MAF(lb/min) 0.827
TP(%) 0.0
O2S B1S12--B2S----
O2B1S1(V) 0.235
SHRTFTB1S1(%) 26.6
O2B1S2(V) 0.910
OBD OBD2
DTC_CNT 1
FUELSYS1 CL
FUELSYS2 N/A
LOAD_PCT(%) 3.9
SHRTFT1(%) 26.6
LONGFT1(%) 21.9
MAP(inHg) 15.7
RPM(/min) 734
VSS(mph) 0
SPARKADV(°) 25
IAT(°F) 81
MAF(lb/min) 0.827
TP(%) 0.0
O2S B1S12--B2S----
O2B1S1(V) 0.230
SHRTFTB1S1(%) 26.6
O2B1S2(V) 0.910
OBD OBD2
DTC_CNT 1
FUELSYS1 CL
FUELSYS2 N/A
LOAD_PCT(%) 3.9
SHRTFT1(%) 26.6
LONGFT1(%) 21.9
MAP(inHg) 15.4
RPM(/min) 739
VSS(mph) 0
SPARKADV(°) 23
IAT(°F) 81
MAF(lb/min) 0.831
TP(%) 0.0
O2S B1S12--B2S----
O2B1S1(V) 0.520
SHRTFTB1S1(%) 26.6
O2B1S2(V) 0.910
OBD OBD2
DTC_CNT 1
FUELSYS1 CL
FUELSYS2 N/A
LOAD_PCT(%) 3.9
SHRTFT1(%) 26.6
LONGFT1(%) 21.9
MAP(inHg) 15.4
RPM(/min) 692
VSS(mph) 0
SPARKADV(°) 20
IAT(°F) 81
MAF(lb/min) 0.823
TP(%) 0.0
O2S B1S12--B2S----
O2B1S1(V) 0.210
SHRTFTB1S1(%) 26.6
O2B1S2(V) 0.910
OBD OBD2
DTC_CNT 1
FUELSYS1 CL
FUELSYS2 N/A
LOAD_PCT(%) 3.9
SHRTFT1(%) 26.6
LONGFT1(%) 21.9
MAP(inHg) 15.1
RPM(/min) 730
VSS(mph) 0
SPARKADV(°) 25
IAT(°F) 81
MAF(lb/min) 0.833
TP(%) 0.0
O2S B1S12--B2S----
O2B1S1(V) 0.285
SHRTFTB1S1(%) 26.6
O2B1S2(V) 0.910
OBD OBD2
DTC_CNT 1
FUELSYS1 CL
FUELSYS2 N/A
LOAD_PCT(%) 3.9
SHRTFT1(%) 26.6
LONGFT1(%) 21.9
MAP(inHg) 15.4
RPM(/min) 736
VSS(mph) 0
SPARKADV(°) 23
IAT(°F) 81
MAF(lb/min) 0.844
TP(%) 0.0
O2S B1S12--B2S----
O2B1S1(V) 0.310
SHRTFTB1S1(%) 26.6
O2B1S2(V) 0.910
OBD OBD2
DTC_CNT 1
FUELSYS1 CL
FUELSYS2 N/A
LOAD_PCT(%) 3.94
SHRTFT1(%) 26.6
LONGFT1(%) 21.9
MAP(inHg) 15.4
RPM(/min) 690
VSS(mph) 0
SPARKADV(°) 20
IAT(°F) 81
MAF(lb/min) 0.812
TP(%) 0.0
O2S B1S12--B2S----
O2B1S1(V) 0.240
SHRTFTB1S1(%) 26.6
O2B1S2(V) 0.910
OBD OBD2
Anyone have any suggestions or see anything wrong? Having the spark adv jump between 18-25, what does that indicate?
-Plug wires are new
-no unusual noises
Live Data
DTC_CNT 1
FUELSYS1 CL
FUELSYS2 N/A
LOAD_PCT(%) 3.9
SHRTFT1(%) 26.6
LONGFT1(%) 21.9
MAP(inHg) 15.9
RPM(/min) 656
VSS(mph) 0
SPARKADV(°) 21
IAT(°F) 81
MAF(lb/min) 0.849
TP(%) 0.0
O2S B1S12--B2S----
O2B1S1(V) 0.715
SHRTFTB1S1(%) 26.6
O2B1S2(V) 0.910
OBD OBD2
DTC_CNT 1
FUELSYS1 CL
FUELSYS2 N/A
LOAD_PCT(%) 3.9
SHRTFT1(%) 26.6
LONGFT1(%) 21.9
MAP(inHg) 15.9
RPM(/min) 735
VSS(mph) 0
SPARKADV(°) 24
IAT(°F) 81
MAF(lb/min) 0.827
TP(%) 0.0
O2S B1S12--B2S----
O2B1S1(V) 0.235
SHRTFTB1S1(%) 26.6
O2B1S2(V) 0.910
OBD OBD2
DTC_CNT 1
FUELSYS1 CL
FUELSYS2 N/A
LOAD_PCT(%) 3.9
SHRTFT1(%) 26.6
LONGFT1(%) 21.9
MAP(inHg) 15.7
RPM(/min) 734
VSS(mph) 0
SPARKADV(°) 25
IAT(°F) 81
MAF(lb/min) 0.827
TP(%) 0.0
O2S B1S12--B2S----
O2B1S1(V) 0.230
SHRTFTB1S1(%) 26.6
O2B1S2(V) 0.910
OBD OBD2
DTC_CNT 1
FUELSYS1 CL
FUELSYS2 N/A
LOAD_PCT(%) 3.9
SHRTFT1(%) 26.6
LONGFT1(%) 21.9
MAP(inHg) 15.4
RPM(/min) 739
VSS(mph) 0
SPARKADV(°) 23
IAT(°F) 81
MAF(lb/min) 0.831
TP(%) 0.0
O2S B1S12--B2S----
O2B1S1(V) 0.520
SHRTFTB1S1(%) 26.6
O2B1S2(V) 0.910
OBD OBD2
DTC_CNT 1
FUELSYS1 CL
FUELSYS2 N/A
LOAD_PCT(%) 3.9
SHRTFT1(%) 26.6
LONGFT1(%) 21.9
MAP(inHg) 15.4
RPM(/min) 692
VSS(mph) 0
SPARKADV(°) 20
IAT(°F) 81
MAF(lb/min) 0.823
TP(%) 0.0
O2S B1S12--B2S----
O2B1S1(V) 0.210
SHRTFTB1S1(%) 26.6
O2B1S2(V) 0.910
OBD OBD2
DTC_CNT 1
FUELSYS1 CL
FUELSYS2 N/A
LOAD_PCT(%) 3.9
SHRTFT1(%) 26.6
LONGFT1(%) 21.9
MAP(inHg) 15.1
RPM(/min) 730
VSS(mph) 0
SPARKADV(°) 25
IAT(°F) 81
MAF(lb/min) 0.833
TP(%) 0.0
O2S B1S12--B2S----
O2B1S1(V) 0.285
SHRTFTB1S1(%) 26.6
O2B1S2(V) 0.910
OBD OBD2
DTC_CNT 1
FUELSYS1 CL
FUELSYS2 N/A
LOAD_PCT(%) 3.9
SHRTFT1(%) 26.6
LONGFT1(%) 21.9
MAP(inHg) 15.4
RPM(/min) 736
VSS(mph) 0
SPARKADV(°) 23
IAT(°F) 81
MAF(lb/min) 0.844
TP(%) 0.0
O2S B1S12--B2S----
O2B1S1(V) 0.310
SHRTFTB1S1(%) 26.6
O2B1S2(V) 0.910
OBD OBD2
DTC_CNT 1
FUELSYS1 CL
FUELSYS2 N/A
LOAD_PCT(%) 3.94
SHRTFT1(%) 26.6
LONGFT1(%) 21.9
MAP(inHg) 15.4
RPM(/min) 690
VSS(mph) 0
SPARKADV(°) 20
IAT(°F) 81
MAF(lb/min) 0.812
TP(%) 0.0
O2S B1S12--B2S----
O2B1S1(V) 0.240
SHRTFTB1S1(%) 26.6
O2B1S2(V) 0.910
OBD OBD2
