Had it tested this morning, failed again. This test is with the addition of an EGR valve and some more tuning done.
From this morning:
HC (PPM) CO (%) NOx(PPM)
Limit 88 0.47 1029
Actual 153 1.22 825 (@ 2175 rpm)
So, I failed on HC and CO but passed NOx - this is the exact opposite of my last test where it passed HC and CO but failed NOx.
The results of my last test were:
Limit 88 0.47 1029
Actual 28 0.01 1184
Not sure what else I can do. I feel like if we tune to lean it out some and bring down the HC and CO then the NOx is going to go through the roof. The catalytic converter on the car (for both of the above tests) is a less than 6 month old 3 way. The most I can think of doing is adding a second cat inline.
Open to suggestions. If I can't pass the e-test ultimately they will pull my registration and turn my car into a lawn ornament.
From this morning:
Limit 88 0.47 1029
Limit 88 0.47 1029
Actual 28 0.01 1184
