I'm using a 2001 Malibu alternator on my 3500 swap and I think it's causing a draw. It uses a 3-wire plug and I have the red and grey wires hooked up to the stock Fiero alternator wires (seems to be connected to a battery light in the dash). I didn't connect the orange (according to the pinout, it's a "Fuse Output- Battery" wire) wire to anything because I didn't see it mentioned in the charging system diagram, only the connector view. After the engine has run, I can hear a high pitched whine coming from the alternator. Also, I think it's causing a slow draw from the battery (don't know how extensive, as I've only had it hooked up overnight once). With the alternator plug disconnected, the whine stops.
Could the orange wire not being hooked up be causing an electrical draw? The alternator seems to charge fine with the engine running, at 13.6 - 14V according to TunerPro. I plan on insuring the car on Monday but until I figure this out I'll probably just disconnect the alternator plug while the car is off.
