Kinda got a few things going on w/ my '87 Celebrity VR. First about a month ago was having problems with stalling and jerking. My mech. tells me its a bad EGR valve thats causing the MAP sensor to read off. OK, I went ahead and bought a new valve ($200) but didnt have the money to have him put it on (I could do it myself, just dont *want* to). Then one night in a po'd mood on the side of the road, I disconnected the the MAP sensor (EGR was previously disconnected). Since then the car has been running GREAT! (I hope this doesnt jinx me). So I'm wondering if I really should have the valve & sensor r&r'd. Im pretty sure the gas mileage might suffer a little & the SES light stays on, but big whoop.
The other big issue(s) I'm having is the motor started making really bad growling sounds. Then the temp gauge started acting weird pegging out to max then going to the 220 mark going around a corner then back again. But the car never drove like it was overheated. After much diagnosing (including a rubber hose!) I determined that the a/c compressor clutch/ pulley was failing. What little driving I did after that, I kept the a/c on (though the rest of the system doesnt work). Kept the growling down while I waited for the a/c bypass pulley to come from Tn. Today I pulled the compressor off & found the pulley had 1/2" of slap in it!!!! As I was installing the bypass pulley I found they forgot to include washers & nuts!!
Afterwards, I decided to check out the cooling system. Found the rad. to be weeping a little. Dang! Does anyone know where I can get a new HD rad. with the brass tanks? All I can find is plastic and for me that just wont do. After pouring 1.5 gallons of coolant into the rad, I went for a drive. Drove like a brand new car!! I mean, you couldnt hear anything from the engine until 2500rpm. Then it just purred. But the temp. gauge is still reading way high. Any ideas?
OK, off my soap box and getting back to overhualing the brakes (another long story I dont want to get into).
Jeremiah
Jeremiah
