i had my car compression checked on all cylinders and they said it was low on compression on all of them. and atold me to use engine restorer to get some of the compression back. is there anything simple besides a major engine overhaul i can do. any help is apreciated. would this make it missfire or is it a totally other probelm thats causing that new plugs,wires,and coil packs.
loss of compression causing missfire
99 Grand Am GT
Tags: None
What were the compression readings? Or did they just tell you they were low...?-Brad-
dont know what the readings were they just said they were low on all of themsigpic
99 Grand Am GT
First thing is, open it up and find out why the low compression. Could be rings. May get away with a re-ring job. Personally, I hate 'em. I go that deep, it gets a total rebuild. There ain't no easy pour in fix. If a mechanic told you to use Engine Restore, he was either lazy or not ASE Certified. That stuff just works short time, and not that well. But the misfire may be another issue.If you are driving a Chevy, everything else, is just a blur. 3.4 Carbon Footprint.
i think hes just lazy and wanted to get rid of mesigpic
99 Grand Am GT
If he never told you what the readings were then dont believe him. Also do you know if the dumbass even did it hot or cold? I say get a tester and do it yourself.1993 EXT. CAB, 3.4L V6 TBI, 5spd manual. Sonoma
yeah i plan on gettin a tester and doing it myself cause to be honest i dont trust the midas people i just took it there for convienience. but considering how they werent gonna make any money off of me they just wanted to get rid of me. another question is would it be better to do it hot or cold cause when it starts to missfire the engine is up to normal running temp.sigpic
99 Grand Am GT
ok thanks ill tyr to get the gauge this week and let you know how it works out. if i remember correctly i think the guy wanted me to leave the car there so he could check it when it was cold. would this be a good gauge to get http://www.cartools.com/Merchant2/me..._Code=MIT05530sigpic
99 Grand Am GT
