Some of you may remeber I decided to see how long high grade race oil really lasts. To that end I picked up a case of AMSOil 5w30 and 5 AMSOil filters. I have not changed the oil since I put it in (now 11,000 miles). I changed the filter at 5,000 miles and topped off the oil as neccassary.
At 10,000 miles I changed the filter again and before I changed the filter I took a sample and sent it off to Oil Analyzers inc to see the condition of the oil after 10,000 miles.
Here are the results:
Miles on Engine: 64,000
Miles on Oil: 10,000
Iron: 14
Chromium: 0
Lead: 4
Copper: 25
Tin: 0
Aluminum: 3
Nickel: 11
Silver: 0
Silicon: 26
Boron: 23
Sodium: 20
Magnesium: 463
Calcium: 2981
Barium: 0
Phosphorus: 1096
Zinc: 1281
Molybdenum: 8
Titanium: 0
Vandium: 0
Potassium: 0
Fuel (% by vol): <1%
Vis @ 40C: N/A
Vis @ 100C: 10.84 (SAE Grade 30 min 9.3, max 12.5)
Water (% by vol): 0%
Soot/Solids: N/A
Glycol: Negative
TBN: 8.9 (Oil should be changed at a TBN of around 2)
OXID: 14.0
NITR: 13.0
Change: No
Analysis Recommendations: No corrective action required. Oil is suitable for continued use. Resample at next regular interval.
Im curious to know if anyone else has done any testing of thier oil on the 3400. I would like to find out if the Zinc and Calcium levels in particular are normal as they seem a little high. If they arent normal, any idea as to the cause?
Iron: 14
Chromium: 0
Lead: 4
Copper: 25
Tin: 0
Aluminum: 3
Nickel: 11
Silver: 0
Silicon: 26
Boron: 23
Sodium: 20
Magnesium: 463
Calcium: 2981
Barium: 0
Phosphorus: 1096
Zinc: 1281
Molybdenum: 8
Titanium: 0
Vandium: 0
Potassium: 0
Vis @ 40C: N/A
Soot/Solids: N/A
Glycol: Negative
OXID: 14.0
NITR: 13.0
Change: No
