Hello 3100 fans:
I've been a bit puzzeled, about this engine misfire I keep getting in a 1996 Cutlass Supreme SL coupe, with the 3100 sfi V6 Gen III engine ? (right?)
Its a hot-misfire issue: after the engine is shut down for NO-less than 5 minutes and not much more than 10 minutes, I get a really bad missfire, (threw a service engine soon light on) diagnosed code was PO300, cyl mis-fires on cyls# 4,5 & 6!
After the following "horror stories" from a Mr.Goodwrench ("head gasket blown!")> I wanted to shoot myself........("leaking intake manifold")>.....I wanted to cry badly.........to a ("set of wires and plugs")>.....big sigh of relief.....and oh yahh, (throw a set of coil packs when you put the plugs in)>....wanted to cry again.......to a possible (leaking injectors)>...I wanted to shoot myself again
What leads me to possible (leak down of injectors, specifically #4, 5 & 6) is that the mis-fires stop after about 1 minute to 1.5 miutes after wide opening the throttle, or raceing the engine in park. ITS ACTING LIKE ITS FLOODED during this mis-fire, (reason I come to the conclusion of a flooding issue) is that it #1 clears up after about a minute, #2, will not mis-fire if say its been sitting for a 1/2 hour or longer.
I have dumped several brands of injector cleaner, on a almost empty (higher concentration, less diluted gas tank) But this has NOT fixed the problem.!!! Which is causing me to suspect that this may be an ignition related probelm as upposed to injector issues.
Times are tight right now especially for the Holidays, (financially speaking) so I'm worried
I really hope someone out there who has had this similar problem in their 1996 or 1997 [3100 sfi V6] in a W car, (i.e. Olds Cutlass Supreme/Pontiac Grand Prix, and whatever the hell else a W car is, Buick Regal?
If someone out there had had this issue, can you send me a email and tell me what you found on your car. I'm hopefull its just plugs and wires, but on the cars I've driven I seldom find a spark plug wire go bad, (especially 3 of them at the same time) and plugs for that matter....which leads me to more serious issues that makes me want to stay in bed and hope it (the car) gets stolen in the driveway so I can by a FORD! (kidding of course)
I'm really hopeing for wires and plugs....HOWEVER..this stupid engine is supposed to have Platinum plugs, (Good for 100K miles of service) before recommended replacement (right?) I'm at 74,000 miles now.
ALL parts under the hood appear to be original to this car. PLug wires never tampered or replaced. So I'm guessing the plugs are original and the coil packs and module are too!
Problem started in late October 2004..........cleared code PO300 2 weeks ago, still sets a service engine soon light on occassion, but now the light came on for a day, Then went off, (stayed off currently) engine continues this hot-restart misfire.
Update:
Now this week, a (anti-lock brake light is on) stays on.......and NO-anti-lock function....Probelm #2 that just started this week!!!!!
And a great big THANK YOU, GENERAL MOTORS, for such high QUALITY and RELIABLE Automobiles!!!!! yaah Right< I'll bet R.E. Olds is Turning in his grave as I speak!
No more Oldsmobiles Huh!!! I'll be driving a 2005 Ford Mustang when they start showing up on the used car lots, (If I can find one) Thats if someone really wants sell their Mustang, because maybee they would like a different color in 2006!
I'm also the owner of a 1971 442 W-30 Holiday coupe..........AN automobile that is 100 times more reliable than the newer front wheel drive W cars.......... (sorry guys, I had to vent)!!!
and yes, I am a fan of the Oldsmobubbles! They'll be burying me inside the 442 when I drop some day!
--Ben
Update:
--Ben
......................We sprayed down the wires/coil packs/ spark plugs with water......Like I tried already.......NO Sparks, No Shorts, NO ARking...........NO change of the missfiring.........Engine continues to miss like CRAZY! Ambient air temp of shop 75 degrees or so.
