I'm finally tearing apart this '94 Lumina to check for leaking fuel injectors, and then if those are OK, replacement of the fuel pressure regulator. Upon disassembly, I found what I perceive to be excessive oil in the intake tubing, in the throttle body, and on the upper intake gaskets I replace a couple months back. I'll attach pics so you can see what I saw. Thanks.
By the way, I never realized how difficult it was to remove that upper intake. The stuff for the EGR, stupid throttle body coolant hoses...gonna make sure it goes back together properly, though.
