I am replacing the heads on my '84 2.8. The new gasket set came with just 6 stem seals, and a packet of "O" rings the size of the valve stem. My heads had stem seals for all 12 valves. Another gasket set had the same packet of 6 stem seals and "O" rings in it too. The gasket set is for 83-88 2.8's. The parts store gave me another package of stem seals and "O" rings to complete the set. I cannot figure out where the "O" rings are supposed to be used. Anyone know, or were both gasket sets just packaged wrong?
2.8 valve stem seal question
RE: 2.8 valve stem seal question
O-rings are most likely for the injectors.-Brad-
Yep.
There are 12 O-rings that go on the top of the valve stem. You will see them when you remove the keepers. They go below the keepers.1993 EXT. CAB, 3.4L V6 TBI, 5spd manual. Sonoma
so that's what that "extra" groove in the valve is for? I checked another head today, and no O-rings in it either. Do they disentegrate with time? Might have to yank the springs off the heads. They are installed, but I have a compressor, or the string in the sparkplug hole is 'sposed to work too.
All iron heads should have them. If not they discintigrated or someone left them out. No aluminum heads had htem.1993 EXT. CAB, 3.4L V6 TBI, 5spd manual. Sonoma
Yes you should have them or else shit loads of oil will run down the stem and the seals cannot cope with it. You may burn oil or get oil in teh exhaust. Remember the intake is under vacuum so it will try and suck oil through the seal.1993 EXT. CAB, 3.4L V6 TBI, 5spd manual. Sonoma
I have one cylinder done so far. Using the rope trick. I will have to come up with a better way to compress the springs. I am using a large washer on the the rocker stud and a front end tool called a "pickle fork" to lever the spring. It tends to slip off. NASA will have to tell me where one of the parts launched to.
Parts store just had the regular spring compressor. They did have a tool for sale for 9 bucks. It was so simple that I just went home and made one. My materials were free, and when it falls into the black hole where all my other seldom used tools went, I won't be as pissed off.
