1993 Corsica LT
3.1 V6 60 degree
As Ludacris says, if you don't like it blow our your "hole".
Exactly what my engine is doing. I have Bosch +4 plats in my engine and it keeps blowing them out, it was one back middle one, well it stopped. Now its the back right one, and it has doen it 2 times in a day. The ole is stripped, helicoils is what has been suggested to me, that the best solution? How hard is getting the head off? I saw the explanation on the site, but I need one with pictures, I will do this but I am trying to learn AS MUCH as possible before I do.
Also on my engine there is a pipe that wraps from the front around the right side into the back. It is 2 parts welded together *top and bottom* and there is a split in it mid way thru the right side. What problems will this cause? Should I just throw some JB weld on it?
3.1 V6 60 degree
