Hi gang,
Been lurking and registered to ask for some help. My wife's '94 Cruiser (3100 SFI- 144,xxx mi.) stalled out Tues., and had it towed to the house
Key on - fuel pump won't prime. No fuel pressure. Tested it 2 mo. ago with a new gauge and it was within spec (I forget the #). I swapped solenoids and it still won't prime. If I jump the test lead to 12V the pump runs, but sounds sick....not sure if I didn't give it a good connection. Gauge got to 34 PSI, but last night it only got to 28 PSI. I bought a pump, but don't want to go through the hassle if this is not the immediate problem. When I jumped the pump and it had pressure, shouldn't the car have started? This makes me wonder if it's something else
I checked for spark, and I got some, but it looked weak, but I didn't have alot of time last night.
The car has new/ newer Delco wires, Champion plugs, Bosch O2, Crank position sensor, fuel filter, upper intake gaskets, oil drive o-ring, emission hoses, and TB cleaned. It normally runs great.
Sorry for the long post. Any advice appreciated
