Hey... For those who don't know me I mainly post on V6z24.com and Domesticcrew.com.
I've built a 3400 motor, with miled port and polish, 3500 upper plenum, adaptor S10 Throttle body. And a few other goodies. It's been off the road since the end of July of 2005 because of a clutch fork failure.
I'm finally ready to start and finish building this thing.
I overfilled the block with oil on purpose. For 2 reasons, 1 To preserve the block while it sat being unused. and 2. To check to see if i have any leaks.
I have 2 Oil leaks, One's my fault for being lazy, (Valve cover Grommets, i already did the gaskets, just put off the gromets)
And the other oil leak is the Rear main seal (already did the intake gasket).
The rear main seal appears to be inside the oil pan. Has anyone done the seal on the LA1 3400 motors? Whats the easiest most effecient and most proper way to do it?
Any recommendations on a Seal? They have a Teflon coated one and a rubber one.
I did search, found nothing except that "oh it's easy" basically.
Does the main cap have to be unbolted? oil pan?
Thanks!!!
Thanks!!!
