I recently purchased a 94 Olds Ciera with only 48,000 miles. It has the 3.1 liter. The temperature guage does not work. I suspect that it is the sensor and not the guage. However, has anyone heard of the guage failing on these vehicles? I am not sure which is the guage sensor. I have four choices:
1. A one-wire sensor in the block by the oil filter which I suspect is the oil pressure switch (there is no oil guage).
2. A two-wire sensor on the intake by the thermostat housing which I suspect is the coolant sensor for the fuel injection system.
3. A two-wire sensor that is threaded into the right corner of the rear head.
4. A three-wire sensor that is installed in the block by the starter.
Any help with problem would be greatly appreciated. Thanks.
