Any tricks on replacing the thermostat on a 3100? After a few hours I managed to work around the throttle body, exhaust manifold, egr, and a couple other obstructions to lloosen the two bolts holding the thermo housing on. Then I realized that the exhaust manifold is less than a half inch away from the thermostate housing, which will make it impossible to remove since it would have to be pulled a little bit away from the block to clear the thermostat itself. Is it necessary to remove the exhaust manifold to get the thermostat out? Is this a GM engineer's idea of a sick joke?
Any info from someone who has changed a thermostat on these engines would be appreciated.
