I'm changing the water pump in my '96 3100. I'm assuming that there is a special tool(hopefully one that AutoZone has) to let you unbolt the pulley from the pump. (Or should I have loosened those bolts before I took the belt off?)
My real question is: The coolant pressure valve on the left side of the engine above the Water Pump is broken. How would I go about replacing that?
Off Topic: I like the new site, I guess I should have visited a little more often, and it may not have been such a shock to me. . .
