ok, so i did my turbo project on this 3100 now it seems whenever i hit 5500 rpm the engine loses power. when i say loses power the tach drops right at 5500 for a second or so then if i let off its fine.
now this is a different problem than if it hits the rev limiter, ive set the rev limit to 4000 once just to see, when it hits the limiter the tach will stay at that rpm not fall until i let off the gas.
so i turned up the limiter to 7000, but still at 5500 it cuts out. any ideas. what should ideal plug gap be for a turbo .025 or .030 or something else?
im only running 6psi right now so i dont see the need to upgrade to better coils its just like it cuts out at 5500 and jerks for a second then i let off cause i dont want to keep doing it.
my only thoughts are possibly try a new coil OR coilpack module assembly. it will do this under load and in neutral so im stumped.
any ideas?
any ideas?
