Well right now I'm in the process or swapping the LIM gasket on my 96 3100. I decided that since I'm at it I might want to look into the 3400 manifolds. With all the clearance issues and EGR changes, are there any year 3400 manifolds that are a direct bolt on which require no modification? It's too cold to spend much time fooling around with rewiring or refitting. I thought there used to be a tread that had a good compatability list but I can't find anything.
Bottom line on 3X00 intake swap
You should have roller rockers so no clearance issues if you do.
97 3400 from a minivan will be threaded on the coolant pipe thing.
The UIM from the earlier years also have the same style EGR adapter, I think a 99 would work fine, if not, you are ODBII, and can use the vertical mount EGR like 2000+ on the 2000+ UIM, the connectors are the same...[URL="http://isaachayes.60degreev6.com/"][SIGPIC][/SIGPIC][/URL][SIZE=1][COLOR="RoyalBlue"][/COLOR][URL="http://isaachayes.60degreev6.com/z26/ss-todo.htm"][IMG]http://isaachayes.60degreev6.com/z26/signature1.jpg[/IMG][/url] [COLOR="#FF4000"]New 2010 project (click image)[/COLOR]
[/SIZE]
oh yeah you want to use the LIM that match your year heads. So 96 style LIM gaskets... Of course you'll need 3400 uppers.[URL="http://isaachayes.60degreev6.com/"][SIGPIC][/SIGPIC][/URL][SIZE=1][COLOR="RoyalBlue"][/COLOR][URL="http://isaachayes.60degreev6.com/z26/ss-todo.htm"][IMG]http://isaachayes.60degreev6.com/z26/signature1.jpg[/IMG][/url] [COLOR="#FF4000"]New 2010 project (click image)[/COLOR]
[/SIZE]
00 upper and lower will fit if you buy a npt tap and tap the coolant pipe hole to fit a threaded nipple1996 beretta w/a 04' 3400 3.5 top end, 42.5lb hr, 180*thermo, t3t4 .63ar 60 trim, LC1 WB, FMIC, greddy rs BOV,TIAL 38mm wastegate,791xv,fidanza,stage III clutch,TG LSD,ffp udp,walbro 255 lph,strut tower brace,22 rear sway,30 front sway,92 5sp tranny,92 subframes,all solid mounts,kyb shocks and struts,eibachs,battery in trunk,tgp map sensor,DHP Powrtuner,euro front and rear and more to come soon...mods sitting in boxes waiting install....zo4 kit,GTU wing,and more..
