I have a 93 3.1 out of my beretta that I am building. I have the cam and the other parts worked out, now I am wondering if I should have the heads shaved .020 or change to 3100 pistons. Anyone have some suggestions of ideas? Thanks
mill heads or change pistons?
Shaving the heads will raise compression
3100 pistons will lower it ALOT
So whats your goal? More or less compression?1993 EXT. CAB, 3.4L V6 TBI, 5spd manual. Sonoma
How do you figure 3100 pistons will lower compression?Originally posted by betterthanyouShaving the heads will raise compression
Personally id shave the heads only as a last resort.. you throw off alot of specs by doing that and make the head more prone to warping.I modify stuff
LOL sorry.. Im in iron head world here. 3100 pistons wont chage compression cuz you already have al heads.Originally posted by GPXSSHow do you figure 3100 pistons will lower compression?Originally posted by betterthanyouShaving the heads will raise compression
Using an iron head, head gasket will raise compression1993 EXT. CAB, 3.4L V6 TBI, 5spd manual. Sonoma
So what makes up the difference in compression ratio from the old 3.1 and the 3100? I thought it was pistons.Originally posted by betterthanyouLOL sorry.. Im in iron head world here. 3100 pistons wont chage compression cuz you already have al heads.
Using an iron head, head gasket will raise compression60v6's original Jon M.
I thought it was the piston dish that changed. I may have some specs, I'll have to search around on my computer.
EDIT: According to my info a 3.1L has a piston dish of 26.4 cc's and a 3100 has a piston dish of 24.6cc's And a 3.1L has a piston compression distance of 1.45in and a 3100 has a distance of 1.47in. Those should make up for the .6 difference in compressionRobby Whitesell
2006 Pontiac G6 GT
1985 Toyota Pickup DLX
9.6-8.8= .8
Brian
3400 SFI V6, 4T60e
WTF? Forget it.Brian
3400 SFI V6, 4T60e
