Originally posted by fivepointhustla
View Post
ls6 springs
any 1?Clean Feet Pet Clean Up
Pet Waste Removal Omaha
We offer dog waste removal and cat waste removal services.
(402) 320-3824, We service the Omaha, Ne. metropolitan area.
Originally posted by fivepointhustla View Postany 1?
of course they'll fit... you'll have to check the install height though.
They look like a standard seal and slide right over the stem, I just used a socket to tap them into place. And the valve slipped through with no problem.Originally posted by rickykline View Postis it a umbrella seal? or a push on? or what?
I've seen too many seals get chewed to hell in the race motor due to them not fitting tightly so I wasnt about to play games, I got these found out they fit and I was happy.
great job.. thanks1996 beretta w/a 04' 3400 3.5 top end, 42.5lb hr, 180*thermo, t3t4 .63ar 60 trim, LC1 WB, FMIC, greddy rs BOV,TIAL 38mm wastegate,791xv,fidanza,stage III clutch,TG LSD,ffp udp,walbro 255 lph,strut tower brace,22 rear sway,30 front sway,92 5sp tranny,92 subframes,all solid mounts,kyb shocks and struts,eibachs,battery in trunk,tgp map sensor,DHP Powrtuner,euro front and rear and more to come soon...mods sitting in boxes waiting install....zo4 kit,GTU wing,and more..
ok so i got the locks, but im guessing the retainers come separate from the locks??? i cant really find a good p/n for them on comps site, and i dont know the stock dia for them to use for the retainers, so i need some help on that, thanks
I'm using P/N CCA-774-12 from Summit $46.39. they are LS1 retainers for use with the 623-16 LS1 locks.Originally posted by gectek View Postok so i got the locks, but im guessing the retainers come separate from the locks??? i cant really find a good p/n for them on comps site, and i dont know the stock dia for them to use for the retainers, so i need some help on that, thanks
my springs are made for the LS6.. Comp p/n 26915. They can come in a set of 12 or 16 from Summit. The retainers should fit fine.Originally posted by gectek View Postok kool, but i remember you used the comp cams beehives for the V6, im using the LS6...are they the same dia and can use the same retainers
