My Fiero of course has the sensor in (more or less, as it is turboed) the stock location.
This question is in regard to another front engined sports car I have just finished building, using a 3.4 Camaro engine.
It wasn't possible to use the stock Camaro twin sensors in the exhaust manifolds (one of the first thing sI did was chuck them and modify some bored out Fiero tubular manifolds to suit). I was concerned with the fact that the sensor would now be aboput 2.5' downstream, so I fitted a heated sensor to get proper readings quicker.
I later talked to a guy who gets cars through our emissions testing and he said that a regular sensor installed way downstream withh still work, it will just take longer to heat up. Was I being worried about nothing - could I have used a stock sensor that far away from the engine?
This thing took a year and a half to finish, but very interesting to do. Pic at http://www.rhodo.citymax.com/i/non-rhodo/March07a.jpg and http://www.rhodo.citymax.com/i/non-rhodo/DIS2.jpg
I used a 94/95 engine but backdated to a 1990 or so OBD 1 ECM for ease of programming - much rather send the chip out than have to send the whole computer. It meant losing the SFI, but I kept the DIS, which frankly would make a nice conversion on the Fiero - it would save me having to rebuild my distributor every few years from the effects of the heat from the turbo. But since I am using the hole in the crankcase for my knock sensor already I'd have to figure out where to relocate it so I could install the crank position sensor in its place.
