Does anyone know where I could find the answer to my question about the studs?
3.1 heads w/LS6 Springs NEED Shims?
Which roller rockers are you referring to?-Brad-
that's what i'm using on my 3500Originally posted by rickykline View Posthttp://store.summitracing.com/partde...930+4294789255
those are the springs i think im going to buy for mine.. revving to 8k would be nice..
So, these ones? http://www.60degreev6.com/store/inde...d&productId=33
From the Product Description...
Originally posted by BenThey were designed for the iron head setup, which you can use their rocker studs to get an adjustable rocker arm setup. Or, you can do what I did and reuse your stock nut on the stock stud and just torque it down. Stock pushrods worked for me just fine. You should check your pushrod guides as a reliable source has told me that the groove needs to be ground down some to fix new geometry. Otherwise you risk breaking a pushrod or your guide, neither of which is good.-Brad-
